02 400ex rear axle knocking
Hey guys, I have a problem here, bear with me,
Yesterday I was riding when I started hearing a knocking/clunking sound coming from the rear. Took the bike back to the garage and noticed the right rear hub had came loose. tightened it back up. when i took it out again it is still knocking when i make a right turn. If i make a left, no knock. If i put all my weight on the right and turn right, no knock?
Now i have noticed the rear axle has play up and down/front to back when it is jacked up but no side to side. also, the chain when rotating gets tight and then loose.
Anyone have any ideas here?
Thanks everyone
Thanks everyone
I agree, also, the crush tube between the bearings may also be worn/rusty/damaged, so take it all apart and get a complete rebuild kit. Or, if you have some spare cash laying around, nows a good time for a tapered roller carrier replacement, 4 times as strong and probably the last set of bearings you will need.
DeFox500
08-14-2015 05:59 PM
