Lower a-arm bushings
Old Sep 4, 2011 | 12:41 PM
cudavic's Avatar
Default Lower a-arm bushings
How do you get the bushings out to replace them with new ones? The inside one is broken off at the collar.
Old Sep 4, 2011 | 01:16 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
you should be able to push it out from the other side- with a screw driver or something...
Old Sep 4, 2011 | 07:30 PM
cudavic's Avatar
BG, do you need to take the arm off completely or just drop the inside?
Old Sep 4, 2011 | 08:20 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I jacked up the on the frame to allow the tires to hang- removed the tire and then removed the a-arms & shock and replaced all the bushings (using a small flat head screw driver to pry the old bushings out) - it was all pretty easy.
I guess it depends on which bushings you're looking to replace...
It's a lot easier to do the bushings when the a-arm is out.
Also- grease the bushings before you tighten the a-arm bolts. I found when I tried to grease the a-arms after I tightened the bolts, it didn't allow the grease to squeeze out the ends and created an air pocket in the bushing- preventing the grease from going in.
You'll see what I'm talking about-
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
