brake light switch
Welcome to the forum! The brake light switch is in the "tee" where all three brake lines mount under the front panel in front of the fuel tank.It screws in the back of the "tee" with the wiring connectors. Its a pressure activated switch that works off brake pressure. OPT
On parts breakdown from 91-93 doesn't show the brake switch ,but on the 94 Trail Boss shows it on the back of the inline block for the three brake lines, part #4110164. Hard to find on the 94 I do remember this! the inline block is mounted to the frame (there is a hole in the frame) and the switch is on the other side of the frame on the inline block under the fuel tank! Reach under the tank and see if you can feel it! Get back to us! OPT
KimSJoh
14
Jul 18, 2015 07:20 PM
