1983 Honda ATC 200 goes only into first but wont move
Old Sep 16, 2011 | 12:12 AM
DigitalDwarf's Avatar
Default 1983 Honda ATC 200 goes only into first but wont move
So, I was out at Silver Lake State Park Sand Dunes enjoying a nice brisk morning. I was climbing all of the hills (sometimes having to down shift on the fly). I stopped my trike on a flat area and put it into neutral. I then put the bike into first gear and the bike wouldn't move. It revved up and the wheels sometimes wanted to move partly, but it wouldn't move.
I had to put the trike into neutral and push it out.
Now here is the dilemma:
Bike will shift into neutral and first, but when i try to shift into the other gears, the pedal will go down but the shift indicator does not spin indicating a shift.
I took the panel off to look and the clutch and gears and one of the bolts unloosened itself and is now bent. See pics...
So I fixed the bolt in the pressure plate, and reassembled appropriately, but now the bike will not shift into gear and engage. I am able to put the trike into first gear, but when I throttle up it will not moved (like the clutch isn't engaging. Any ideas why this?)
I tried to the clutch adjustment. I screwed it all the way counter clockwise then loosened it a 1/4 turn. The shifter pedal was almost to stiff to shift into gear at this adjustment, but I was still able to get into first by pressing down extremely hard. When in first it wouldn't move. I tried to loosened the screw clockwise at more intervals and it still wouldn't engage the clutch.
I think the pressure plate bolt bent when it hit the centrifugal clutch (see pic). Both clutches spin by hand, if that makes a difference. I didn't find much at the bottoms of the case except two or three small metal shavings.
My question is would this cause the bike not to shift or engage when I give it throttle?
Thanks
Caleb
Old Sep 16, 2011 | 02:26 AM
MIsuzukilt230s's Avatar
Not that it matters but is this a 200s or 200m or 200e or just an old 200? Have you pulled the clutch apart to look at the friction plates? Was it acting up prior to the time that you put it in neutral for a break?
Old Sep 16, 2011 | 08:34 AM
Thanks for the reply! No, I have not torn down the clutch yet. I figured it was just that bolt that was not allowing the bike to move, so I replaced that. How would the discs go bad from that bolt coming loose? It moved great until the bolt popped out. What should I look for in bad discs?
It is a plain old ATC 200
Old Sep 17, 2011 | 01:02 AM
When inspecting the clutch look for wear on the fingers of the basket. Check the steel discs for signs of warping or heat marks. Check the fibers for sufficient material, there is a spec but I'm not sure what it is...
Old Sep 17, 2011 | 01:04 AM
Btw how did the honda do at the dunes before it took a crap? Paddles or just dirt tires?
Old Sep 17, 2011 | 07:52 AM
Will have to tear it back down and look this weekend. The trike climbed better than I thought it would. Climbed all the hills (including test). It wouldn't climb some parts of Test though (where the sand was really soft). I was using dirt tires
Old Sep 25, 2011 | 03:34 AM
Just wondered if you've made any progress on the trike...
Old Sep 25, 2011 | 09:11 AM
I did and I didn't. The movement problem was because I was being an idiot and did not adjust the clutch correctly. I took it back out into the dunes for 2 hours, came down and parked it. I left it for ten minutes came out and there was a puddle of oil on the ground. I noticed the oil was leaking out a little hole on the bottom of the pull start case. Took that apart and tightened the bolts. I then took it back up for 15 minutes. When I shifted into second gear 15 minutes later the trike bogged down and shut off. I looked at the engine and it was smoking (like it was going to start a fire ). Took it back down and oil started leaking out again and the engine smoked for awhile longer with the trike off.
I am thinking to oil coming out of the pull start is because of a seal/o-ring behind the stator, but no idea why it would bog down and shut off and then smoke?
Old Jul 29, 2020 | 04:43 AM
Michael Horsford's Avatar
Default Man that is definitely the problem
theres not a lot of difference in the discs new & wore out ... But its visible more so by feel .... I replaced mine used the updated higher tension springs .... All you'll have to do is order the special honda hub socket .. Clean out the outer rim of the oil pump and do your best to get the junk laying in bottem of the engine case .... I belive i spend 24 bucks doing mine ha ... I'm sure you have long since fixed it .. But i am keeping 3 going i love these tanks
greg74
Sep 10, 2019 03:03 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
momma's bike
Aug 6, 2015 09:49 AM
DeFox500
Technical and How-To Articles
Jul 26, 2015 02:07 PM
CRamshaw777
Jul 18, 2015 05:46 PM
