Blaster misfire at full throttle???
Old Sep 19, 2011 | 08:26 PM
quepasa69's Avatar
Default Blaster misfire at full throttle???
Ive got a 01 yamaha blaster. Bottom & top end were rebuilt last spring. Cylinder is bored out .5. After rebuild it seems to miss out at full throttle. Runs fine during idle and 1/2 trottle. When at full throttle after a bit it starts to cut out and as long as I slow back down to 1/2 it will run just fine. Could it be jetting? Pulled carb all apart and blew out all jets, everything still clean. Not sure where to go with this next. Please help!
Old Sep 19, 2011 | 09:08 PM
JLsparky7's Avatar
Check out the link in my signature for some blaster vids
Throw a new plug in it and double check your grounds. Sounds like it might be a bad coild or stator. CDI and voltage regulator should be fine.
Old Sep 19, 2011 | 09:31 PM
quepasa69's Avatar
Put in new plug. Same problem. checked grounds an seem to be tight. Plug did look a little rich. Have not done stator or coil yet, just wanted to make sure it wasn't anything else.
Old Sep 21, 2011 | 12:38 AM
JLsparky7's Avatar
I'd replace the coil next.
Old Sep 21, 2011 | 07:08 AM
papa hogg scoot's Avatar
Loved
Community Favorite
May want to read the ohms on the plug resistor [spark plug boot] on the end of wire first! This the most over look part in my town!If bad it could cause your problem!
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ronk407NY
Feb 13, 2016 11:05 AM
Polarisman1123
Sep 13, 2015 10:06 AM
blpersinger
Jul 15, 2015 09:56 PM
