polaris 400
Old Sep 25, 2011 | 10:40 AM
stiffs's Avatar
Default polaris 400
why cant i get my 1998 polaris 400 to go into nuetral or reverse
Old Sep 25, 2011 | 10:50 AM
stiffs's Avatar
please help me figure out how to put my polaris in reverse and nuetral
Old Sep 25, 2011 | 11:06 AM
Polaris 400 what model?? Just guessing,if its a Scrambler I would think you have a linkage problem??Or a loose/stripped shift lever(belcrank) on the tranny?? If its an Explorer then its usually the shift box that wears out causing the shifting problems?? A little more info on the model Please! OPT
Old Sep 25, 2011 | 06:21 PM
boots29's Avatar
Question 1994 Polaris 400L 4x4
Hi....I'm new here and looking for help. Sometimes my Polaris won't shut off with the kill switch or the key but when the key switch is working right it runs great but when the key switch is not working right it runs like crap. Any ideas? I really appreciate any information you guys might have.
Justin
Old Sep 25, 2011 | 08:15 PM
Justin
Welcome to the forum! This involves removing the tank plastic,but I would check on the left side of the atv at the circuit board where the black wire from the cdi ties in with all the black connections first. Plus while there you can find the wires that go to the key switch(routed under the headlight housing) and also the emergency kill switch wires that goes to the circuit board and check connections(all are color coded). Hopefully you'll find a bad connection there.Plus if everything looks ok,you can pull the ignition switch wires from the board and ohm them out(could be just a bad switch?) OPT
Old Sep 28, 2011 | 03:51 PM
boots29's Avatar
Default Thanks for the information Old Polaris Tech!
I will try what you said and see if that helps. Again, thanks so much for the information.
Justin
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
