2000 Artic Cat 300 4x4
Old Oct 2, 2011 | 09:45 AM
flyway1's Avatar
Default 2000 Artic Cat 300 4x4
My ac won't start and when cranking the engine and holding the gas on, the engine has a banging noise. I am getting good spark and gas. If I take the hose off between the carb and the air intake, it will start but with the gas all the way pressed, it will just barely run.
Old Oct 15, 2011 | 08:00 AM
nmcatman's Avatar
Default Sounds a little like mine...
Does removing the air filter have the same effect as removing the hose? Mine would barely idle...was pluggage in the carb.
Old Oct 16, 2011 | 12:59 AM
Williebee's Avatar
Post 2000 arctic cat 300 4x4
welcome to the forum flyway1 and nmcatman...
I'm assuming that the banging noise you're refering to is back firing
if i'm correct and it's back firing through the carburator it be the intake valve is out of spec's
if it's back firing through the exhaust the exhaust valve is out spec's !
But i agree with nmcatman try it with the air filter removed and see what happen's , if this doesn't help try removing the carb for a good cleaning , i would also suggest that you check your valves clearance to see if they're within spec's ; it's been awhile since i adjusted the valves on my old 1993 Suzuki 300 KQ 4x4 so i don't remember the spec's !
There's a site on an older post that gave the name of this site where you can download the service and repair manual free in pdf , it's a lawn and garden site ; but it doesn't cost anything for the download ,i think it called Ken's lawn and garden repair !
If you go back down and look at the old post's you should be able to find it , i have a repair manual that covers all the major brands , but i left it at my cousin's in Calhoun Ga !
Hope this help's you get your 300 4x4 going they're great running and reliable quad's when they're serviced regularly , my cousin owned a 1989 Suzuki LTF4wd Quad runner and a new 1993 LTF 300 ; i bought the 300 KQ after my cousin passed away in aug - 1999 !
I sold it to my brother november 2005 and it still run's great , well good luck with the quad !
williebee.............
Last edited by Williebee; Oct 16, 2011 at 01:20 AM. Reason: I just got ahead of myself as i often do when i'm in a hurry !...
Old Oct 16, 2011 | 02:08 AM
Williebee's Avatar
Post 2000 Arctic Cat 300 4x4
flyway1 this is the site for the free service and repair manual i was talking about for the free download in pdf file..... www.K&TPartsHouseLawnMowerPartsAndChainSaw Parts.com Hope this helps !
williebee..........
Old Oct 16, 2011 | 08:50 PM
Williebee's Avatar
Default 2000 Arctic Cat 300 4x4
williebee..........
Make that http://www.k&tpartshouse.com !
I had the url to long , sorry if the link didn't work !
Well that link didn't work either , just use your internet browser to search for : www.K&tpartshouse.com , i can't access the link from the forum had to use google to access the site !
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
