drowned can-am outlander
Old Oct 7, 2011 | 10:23 PM
Deanna's Avatar
Default drowned can-am outlander
I have a can-am outlander and i drowned it changed oil 4 times pulled plugs and turned over to empty water in engine removed air filter and i think we have it all dried out go to run it i get a message that says check engine then low oil and it is full what could be wrong? don't know what elese to do
Old Oct 8, 2011 | 09:23 AM
95wolv's Avatar
Sounds like the water shorted out a sensor connection, may be a good idea to pull all the electrical and sensor plugs apart, give them a spritz of WD-40 to displace any water (or use an air gun to blast them dry) then put a dab of dielectric grease in each one before reassembly. ECU inputs are real picky about moisture and corrosion, the only drawback with newer quads, almost as many sensors and hookups as a new car. Dry out all the connections, pull the battery to give the ECU a chance to reset, and see if that helps, if not, you may need to go to the dealer so they can hook up and see where the fault is coming from. Good job on the oil changes and checking for water in the block by pulling the plug, nasty things happen when you try to crank over a combustion chamber with liquid in it !!!
Old Oct 10, 2011 | 07:57 AM
Deanna's Avatar
thank you we will try that!
Mar 22, 2016 09:55 AM
Mar 21, 2016 06:30 PM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
