Polaris sportsman 500 4WD Battery Shorted
Old Oct 11, 2011 | 01:57 PM
drewpolk's Avatar
Default Polaris sportsman 500 4WD Battery Shorted
My Sportsman 500 is a 2003 year model and while I was installing a new battery and did not notice the + and +and _ posts were opposite as original until it was when I turned on ignition key and below and to the left I believe where the smoke billowed up and crackled . What exactly will fry near the battery case and what is the part called? Is this a fuse or a solonoid?
Old Oct 11, 2011 | 03:14 PM
Hopefully if your lucky you only melted the 20 amp thermal circuit breaker that's near the battery (encased in a plastic pouch),and didn't get past that to the cdi,speedo,etc! Plus could have melted the starter solenoid internals that's attached to the battery case? Slice the pouch and see if wires are melted on the square circuit breaker. 3087196 is the number for the starter solenoid(magnetic switch), 2200593 is the number for the replacement circuit breaker if needed! Place the battery back in right and you can temporarily jump the circuit breaker(if need to) to see if you still have power to speedo,starter works,cranks up,etc and no other damage !OPT
Old Oct 11, 2011 | 03:25 PM
drewpolk's Avatar
Will check these parts this evening. So good to get a reply. Thanks Ol Bud! I can only hope what you suggested is burned is all that burned.
Ol Drew
neilbedwell
Nov 10, 2018 11:02 AM
bikedad3
Jun 29, 2015 08:58 AM
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
May 27, 2015 11:15 AM
