warrior question
Old Nov 18, 2011 | 06:31 PM
jssblues's Avatar
Default warrior question
Recently got 87 warrior been working on...had a few things to fix so now I got fuel and spark, still got starter clutch issues I think, but pull start is broke so I want to try and start by using a drill and socket at the crank I think, where the pull start was....WHICH ROTATES WHICH DIRECTION??????? Only way I have been able to start is by roll starting ....why will it not fire when cranking over with a drill ???? Is it because I am leaving compression relief valve open????...any help would be greatly appreciated...
Old Nov 18, 2011 | 08:00 PM
jssblues's Avatar
C'mon someone on here got to know something your an old warrior....at least which way the crank rotates...clockwise or counterclockwise....
Old Nov 18, 2011 | 10:25 PM
TCNJ's Avatar
Get a shop service manual for it, good luck. Great machines, I owned 3 of them in my riding career.
Old Nov 19, 2011 | 05:10 AM
jssblues's Avatar
I Got a manual and none of my questions are answered in there..
Old Nov 20, 2011 | 01:23 PM
Doctorturbo's Avatar
GOT BOOST!
Here is a way to find out and answer your question. Put the quad in 4th or 5th gear and push the quad foward and look and see which way the crank turns. Done.
Old Nov 20, 2011 | 02:21 PM
Raptor450's Avatar
When you're cranking it with a drill, get it turning over and then take the compression relief off. The engine can't build any compression with the exhaust valve open (which is what the compression relief does).
The crank probably rotates couter-clockwise, but I'm not 100% sure.
Old Nov 20, 2011 | 02:25 PM
jssblues's Avatar
Thanks for the info guys....
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
