250r, carb and reed questions
Old Mar 15, 2001 | 10:17 PM
stephen's Avatar
i own an 86 trx 250r, i have fmf fatty & power core 2 silencer, wiseco piston, carbon-tech reeds. does a reed spacer add sufficient enough power to make it worth the 20 bucks???? is the power noticeable? thanx
Notify Moderator
scottbl99
Senior Member
emmett, MI, US Date Posted: Mar 14, 2001 11:55 AM
as a reliable engine builder ...CURTIS SPARKS has said do not put them on they only hurt the engine for power...spend 45 dollars and get a 98 cr reed cage is what he said it is just like the paramid reed cage and it boost your power and increase you r horse power
Notify Moderator
stephen
Senior Member
parsons, KS, US Date Posted: Mar 15, 2001 11:13 AM
do you mean the reed cage off of a 98 honda cr dirtbike??? if so, do the bolt patterns and everthing match up, or is there and mods necessary? is this cage just as good as the aftermarket ones? how much of a power increase should i expect? one last question, i want to get a bigger carb, i have fmf pipe & silencer, K&N w/lid removed, and hopefully a bigger reed cage,,, what would you recommend? i was thinking about a keihin 38mm pwk air striker. i'd hate to get one that is too big, but at the same time, i don't want one that isn't large enough for the portwork i plan to do later in the future. thanx a million
Old Mar 16, 2001 | 02:25 AM
trapperb1's Avatar
Don't bother with the spacer.
You want the best reeds? Get Delta V-Force.
Second best (what I use in my 86 R) are Boyesen.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
