What's needed for a complete blaster engine rebuild
Old Nov 20, 2011 | 12:20 PM
Oisincas's Avatar
Default What's needed for a complete blaster engine rebuild
Got a yamaha blaster but the engine is seized what all do I need to fix I mean everything needed crank piston connecting rod anything else also what would the price work out around thanks in advance and this forum is awesome answers to any question and the answers are all right so far thanks
Old Nov 20, 2011 | 03:59 PM
HMT Racing's Avatar
What is siezed. The piston or a crank bearing or what? First thing to do is tear it down and look at the gears and bearing and so forth hard to tell without knowing why its seized
Old Nov 20, 2011 | 04:28 PM
Oisincas's Avatar
The 2 stroke bottle/tank failed causing it to sieze
Old Nov 21, 2011 | 09:27 AM
HMT Racing's Avatar
Well you will need to replace crank, rod, piston and pin, bearings and seals, will need a full gasket set, oil injection block off kit and start pre mixing your gas. We mix 32 to 1. Good luck
Old Nov 22, 2011 | 08:53 PM
TacticalRedneckofKentucky's Avatar
thats why we always disable the oil injecter, sometimes you can hear it when it fails. But i just go to the trouble to mix it myself..
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Dieseltrash
Jun 6, 2015 09:53 PM
