Need help 2006 dvx 250
Old Nov 27, 2011 | 01:18 PM
dweber19's Avatar
Default Need help 2006 dvx 250
Ok, the battery crapped out so i replaced it, just within one or two rides the follwing happened, if you turn the key on no lights come on ie neutral light or high beam lights on key ignition panel and starter button does not work, but if you jump the solenoid to start it it runs and lights work, also with the engine running you can hit the starter button and hear it work, i replaced the solenoid thinking that was problem but it wasnt, any help would be greatly appreciated
Old Dec 21, 2011 | 06:21 PM
rogerking85's Avatar
Exclamation I have same problem.
Im getting tired of jumping it. This is my wife's and its a pain in my ---. Did you figure this out?
Old Dec 22, 2011 | 02:44 PM
Williebee's Avatar
Thumbs up Need help 2006 dvx 250
Did you find/fix the problem you were having on your 2006 dvx 250 ?
If not you will probally find that you have a short in the wiring harness like my friend did , he did everything you did , battery ,solenoid and he also replaced the starter relay , the fix for his quad was in the wiring harness ; he had to remove the plastic's to find the problem a chapped wire in the wiring harness near the handlebars/steering/stem was rubbing again't the frame !
I hope you got it fixed , if you did it would be helpful to other's in the future if you'd post a reply to your original post !
williebee.........
Old Dec 28, 2011 | 10:05 PM
dweber19's Avatar
sorry for the no reply, my laptop crapped out and finally got it back, as for the problem i have yet to figure it out, iguess i will start the wild goose chase trying to find a broken wire, that seems to be my last resort, i really do apologize for not keeping up on my post.
Old Dec 30, 2011 | 02:51 PM
dweber19's Avatar
Default Fixed !!!!!!!
Boy do i feel stupid, it was the 30 amp main fuse. I always try to make things more difficult than they actually are.
Old Jan 11, 2012 | 02:52 AM
Williebee's Avatar
Thumbs up need help 2006 dvx 250
Good to hear you got it fixed we've all done that and been there , i just got back online myself my 2002 HP pavillion's cpu fried from to many file's and not enough memory ; got a new laptop after christmas !
Again i'm glad it was something as simple as the fuse .
williebee...........
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
dwhipper61
Aug 27, 2015 11:01 AM
