Yamaha 350 Warrior Engine Clatter and power loss
Old Dec 20, 2011 | 08:58 PM
jedijingle's Avatar
Default Yamaha 350 Warrior Engine Clatter and power loss
Hello,
I have a 350 Warrior that I got from a friend with a known problem. The engine is making a contant clatter noisy that coencides with the rpm. Recently the engine started to overheat and lost power. I need some advice where to start. Top end or bottom end piston slap. Thanks in advance. john
Old Dec 21, 2011 | 05:23 PM
Raptor450's Avatar
Well since you have to start to tear the engine down from top to bottom anyway, I would pull the head off first and check the valves and cam operation. If you don't find a problem with that then you can easily pull the cylinder off and check the piston, cylinder walls, and connecting rod bearing. Usually if the connecting rod bearing is bad it will lock up.
njrider64
Jul 4, 2017 01:40 AM
txkevin
Sep 21, 2015 02:02 PM
mikey426
Jun 17, 2015 03:53 PM
wildbill59
May 28, 2015 12:05 PM
