How Hard Is It To Get Right
Old Dec 29, 2011 | 08:39 AM
_Kong_'s Avatar
Default How Hard Is It To Get Right
Why don't ATV manufactures put the battery in a super easy accessible place. Why tuck it under the frame and plastic in odd places. To add something to a battery post, or change it out should not take an extra 30 minutes of disassemble time. My son's 90 Sportsman has it right, pop the seat and its right there on top with easy access. My 500 has me crawling around in the dirt to take off a strap, wrestle with a cover, and then tilting the battery to get it out of the box. Many other brands are much worse than this, requiring fender pulls. Short of putting air in the tires, this should be the easiest thing you have to fiddle with on a quad.
End of rant, carry on.
Old Dec 29, 2011 | 08:59 AM
Specta's Avatar
The battery on my Honda is right under the seat.
The battery on my Polaris Touring is right under the front lock and ride box.
Bot easily accessable.
Old Dec 29, 2011 | 10:12 AM
davidaz's Avatar
The older Sportsman batteries are much easier to remove and install if; 1) You stop by a machine shop and custom fabricate your own special tools and 2) you stick your arm in a vice and snap it half way down the forearm to give it the extra flexibility needed to bend 90 degrees twice to reach the battery location. Then you need to know the secret Polaris 'combination' needed to extract the battery through the maze of frame members and wiring harnesses requires; spin the battery twice to the right, lower it, spin it left once and move it forward, spin it back to the right then turn it until its on its side....
It's totally worth spending the extra $ to get the Odyssey battery and be done with it. They usually last at least 7 and up to 12 years. They don't surprise you by going dead suddenly (and at the worst possible time), they start slowly winding down at the end of their life, so you get a warning.
Old Dec 29, 2011 | 10:24 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
can-am did, does not get much easier then slipping it right out the back after releasing one rubber strap....
Old Dec 29, 2011 | 10:34 AM
Could be the reason my old hands don't want to work anymore along with the RA! Guess you figured out what it takes to be a Polaris tech OPT
Old Dec 29, 2011 | 12:33 PM
davidaz's Avatar
Smile
That's because there's no room in the front part, it is taken up by a super high tech three wheel drive system that senses which tire is stuck on the rock so that it can send power to the other front tire that is up in the air.
Old Dec 29, 2011 | 02:28 PM
bobx2's Avatar
That's funny. I don't care who you are, that's funny!
Old Dec 29, 2011 | 02:38 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
huh? I don't get it.
The visco front diff takes up no more room than any other front diff.
Sounds like you've never been on a new can-am.... because what you described in your response has never been the case on any of the 7 can-am's that I've owned
Old Dec 29, 2011 | 03:08 PM
TLC's Avatar
TLC
My ATV sat for 6 months and and the battery was dead so I jumped started it with my truck. Can,t even imagine an easier place to place a battery on a ATV.
Old Dec 29, 2011 | 04:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you think your atv is bad you should see what i have to take out to get to my battery on my apex
