How Hard Is It To Get Right
Old Dec 29, 2011 | 05:49 PM
850 trailrider's Avatar
Got that right Stendori 1/2 hour job to pull out battery and stuff on my rx1 warrior four stroke sled just to get to oil filter and then hope I dont drop bolts down to belly pan
Old Dec 29, 2011 | 06:32 PM
Specta's Avatar
Originally Posted by davidaz
That's because there's no room in the front part, it is taken up by a super high tech three wheel drive system that senses which tire is stuck on the rock so that it can send power to the other front tire that is up in the air.
At least it works all the time and not when "it" wants to work. The "On-Demand" 4-wd only works after certain criterial has been reached, not when you engage it.
Old Dec 29, 2011 | 07:18 PM
davidaz's Avatar
The only system that engages right away is a locker system but you have to stop ons steep hill or in the mud. I can wait for the wheel to turn 1/8 To engage. Momentum is critical. I wish I could the my Polaris frame, suspension and awd system powered by my Rotax with the reliability of my Yamaha, Honda or Suzuki.
Old Dec 29, 2011 | 08:04 PM
Specta's Avatar
provided that the rpms drop below 3100 rpm after the 4-wd has been engaged and it does not work when decellerating into a corner
If you're headed into a bad situation why do you wait until your stuck to engage the 4-wd??
I've ridden both, I'll take the CanAm 4-wd to the Polaris.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Whitelx1
Oct 2, 2015 10:55 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
