pull star for 850 xp
Old Jan 4, 2012 | 08:38 AM
ellis_dave's Avatar
Default pull star for 850 xp
Does anyone kow if there is a kit to put a pull start on a 2010 850xp touring?
Old Jan 4, 2012 | 08:44 AM
Don't think there is. I believe there is one for the 550 but not the 850.
Old Jan 4, 2012 | 09:08 AM
TLC's Avatar
TLC
Probably pointless since no one could pull over a 850 anyways. Maybe kick start it if your lucky.
Old Jan 4, 2012 | 10:50 AM
HELLS BELLS, it's hard enough sometimes to pull start a 500 let alone an 850 but then again maybe I'm getting weak in my old age and have been bitten one too many times on the 500 when it tries to ****** the rope out of your hands(learned real quick to use two hands!!) OPT
Old Jan 4, 2012 | 02:28 PM
ellis_dave's Avatar
there's pull cords on 800 bombardiers there's cords on 750 brute force and 650 and 700 actic cats why does everyone thing it would be impossible to pull over the 850.
Old Jan 4, 2012 | 03:51 PM
It would need a compression release of some sort, I imagine.
Old Jan 4, 2012 | 06:30 PM
850 trailrider's Avatar
there are a ton of big bore snowmachines 900 -1000 cc that have pull cords not that there fun pulling over especially when cold I've even seen a video of someone pull starting a yamaha 4 cyl 1000 cc four stroke sled by wrapping a strap around clutch and pulling over some sleds even came with pull straps for emergency in there tool kits to use for that purpose I personally like just turning the key But when something goes wrong YOU ARE S.O.L with no pullstart
Old Jan 4, 2012 | 09:25 PM
Checkmate guy's Avatar
I could start all my old sleds with just my hand on the clutch, I drove my 800 XCR Polaris for a whole winter with a broken recoil, rope around the clutch in the morning for first start and then just my hand for the rest of the day, I have also started my 220 hp which is a 2.4L block (2400 cc's) mercury outboard with a rope around the flywheel, I don't see why you couldn't start a 850 with a rope.
I'm 6'4" and 270 lbs so that might have something to do with it
Old Jan 5, 2012 | 02:59 AM
davidaz's Avatar
Probably 95% of the time the reason you might need to pull start is for a dead battery. Get an Oddysey or Interstate battery, then you will only left with a very minute concern about your starter failing in the middle of nowhere. (That will free up your mind to worry about bigger things like breaking an axle or having your injection system fail).
I've finally left my cheap ways behind me when it comes to batteries. In one of my kids quads I had a conventional Interstate battery last over 5 years (without hooking it up to a battery conditioner and sometimes the quad would sit for months). The cheap batteries used to need to be replaced almost every 18 months like clockwork and always failed at inconvenient times.
The AGM batteries for the big bores usually last 7-10+ years and give you a little warning they are going bad by losing cranking power over time, rather than all at once.
Old Jan 5, 2012 | 10:06 AM
TLC's Avatar
TLC
The largest ATV I tried to pull start was a Yamaha 660 Grizzly and its very hard and hurts when it kicks backs and rips the rope handle out of your hand.
The 660 did not have a auto decompression though. My 500 has one and is actually easier to pull over then my 250 Yamaha that did not have on.
Does a 850 have auto decompression? It would make the life of a electric starter last longer also.
I seldom ride alone, so I carry these minature looking jumper cables to jump start another ATV. I even jumped started the 660 Grizzly once rather then try its pull cord ever again.
Valder
Nov 28, 2020 07:38 AM
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 21, 2015 03:03 PM
