bogging down when warm
Old Jan 20, 2012 | 08:55 AM
mikey250z's Avatar
Default bogging down when warm
Ok i got a 90cc yerfdog atv, it starts up fine and will run great for a few minutes, then once its warm it will bog down when i give it gas. I took the air filter off so i could choke it with my hand it, then it will run fine as long as i keep it choked, any help would be greatly appreciated, i have cleaned the carb numerous times and the fuel flow is fine, i also bought another carb and that did not work.
Old Jan 20, 2012 | 09:29 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Could you see light thru the pilot jet and the holes in the side of the main jet holder when you cleaned the carb?
Old Jan 23, 2012 | 09:32 AM
mikey250z's Avatar
yes i thoroughly cleaned the carb
Old Jan 23, 2012 | 07:32 PM
LT80's Avatar
LT80 Expert
Plugged pipe?
"fuel flow is fine"
Yes but for a long enough time? Plugged fuel cap vent?
Old Jan 27, 2012 | 09:33 PM
mikey250z's Avatar
so fuel flow is fine pipes not plugged, recleaned carb again runs about 5 minutes, then starts to bog so i choke it with my hand then it runs like a champ for a few, also if i let it cool down it will run great, it has and auto choke on it, suspecting that is bad any way to test it or how it works???
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
IMLN
Sep 28, 2015 03:32 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Brandon400
Sep 7, 2015 12:20 PM
