Is there a simpler intake system for the LT80?
Old Jan 21, 2012 | 04:33 PM
SPI's Avatar
SPI
Default Is there a simpler intake system for the LT80?
Everytime I need to work on this thing I have to remove like 8 pieces and theyre all from the intake.
Any suggestions?
Old Jan 21, 2012 | 06:10 PM
KFX80Dad's Avatar
Welcome to the forum,
What kind of work are you referring to have to take off all the intake plastic?
Old Jan 21, 2012 | 06:49 PM
SPI's Avatar
SPI
Well, I guess I'm exaggerating a little bit. I was trying to get the plug out to do a compression test and I had to remove some of the intake. It just seems like a lot of friggin plastic.
Has anyone tried the 20mm carb with the K&N filter on it that Midwestminis (I think that's the name of the site) sells?
I've never seen pics of an lt80 with anything other than a stock intake system, so I'm just wondering??
Old Jan 21, 2012 | 09:32 PM
KFX80Dad's Avatar
Instead of going through all the trouble of taking off the intake ducts take the seat off and there is a peice of plastic right over top of the sparkplug. it about 4"x3". I cut mine out and let me tell you it made it a 1000 time easier then going through all that trouble. I can prob change a plug in approx 2 mins. and you have total access to the top end also. Hope this helps you out.
Old Jan 21, 2012 | 10:22 PM
SPI's Avatar
SPI
Yeah I tried that but it seemed like the intake was still in the way. I couldn't seem to push it aside to really get in there. Then again it was dark and freezing cold out so I could be wrong.
Has anyone tried anything other than the stock intake though?
And thanks for replying I will give it another go tomorrow, hopefully I can find somewhere warm to work.
Old Jan 22, 2012 | 09:53 AM
LT80's Avatar
LT80 Expert
The DG carb set-ups (20mm) run OK. You will get more dirt in the motor over time.
Every one that I had (or my riders) the carb fell out of the adapter that they made to bolt it on.
I'm w/ KFX80dad, Once the lil flap is cut off the plug is super easy to get to with a socket and extension.
To remove/install the plug cap: use your left hand and go behind the air tube.
Nothing in the way really.
I'm sure you'll find it easy enough when you can see.
Old Jan 23, 2012 | 09:47 PM
LT80's Avatar
LT80 Expert
I changed a plug.
I do see and understand what you meant about pushing on the air duct.
Old Jan 23, 2012 | 10:41 PM
LT80Pilot's Avatar
I sliced up my intake before I read LT80s comments that it doesn't make much difference. I'm using the uni-filter with a pre-charger. Or, at least I will. Once I get it working again.
Not really sure what the trouble with removing spark plug, but we have Maier plastics; maybe the stock stuff blocks the area directly above the spark plug.
Old Jan 23, 2012 | 10:50 PM
LT80's Avatar
LT80 Expert
The stock plastic does have a flap in the way. I cut it off and it helps alot.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Oct 10, 2015 10:20 AM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
