my shifter shaft is broken n i wanted to know is it hard to replace n what is the pau
Old Feb 1, 2012 | 07:37 PM
treybird80's Avatar
Default my shifter shaft is broken n i wanted to know is it hard to replace n what is the pau
i would like to know what the shifter shaft is called if that is what it is called it had a week spot on it n it broke off so it is stuck in 1st gear and where could i get one
Old Feb 1, 2012 | 07:43 PM
If you're talking about the shift linkage rod,look up your year model atv at Cycle Parts Warehouse. Prices are cheaper than the dealers. If you broke a linkage rod you may have some other problems in the shift box,etc? OPT
Old Feb 1, 2012 | 07:47 PM
treybird80's Avatar
no its not internal is on the outside
Old Feb 1, 2012 | 07:48 PM
treybird80's Avatar
it was welded before n it just snapped
Old Feb 1, 2012 | 07:55 PM
Since I've found out it's an Xpedition 425,makes it a little clearer If you're talking about the shift lever then you can still find it at Cycle Parts Warehouse along with the internal shift assy if the foot lever broke off there and a new foot lever can't be installed. OPT
Old Feb 1, 2012 | 07:59 PM
treybird80's Avatar
k thanks
Old Feb 1, 2012 | 08:04 PM
The Expeditions were bad about stripping out shift levers and I've had some come in that were tack welded on the shift shaft also! If the internal shift assembly splines are messed up you will have to replace it OR just tack weld the new shifter back on or it will just slip again!. OPT
Old Feb 1, 2012 | 08:10 PM
treybird80's Avatar
i didnt find a part on the site
Old Feb 1, 2012 | 08:18 PM
Look under Polaris atv parts,find your model and look under ENGINE MOUNTING! The shift lever is shown out to the side of the engine Part # 5630960-067 around $35! A little pricy,but you might check Ebay or some salvage yards or try to match the old one up on some aftermarket sites. OPT
Rocketx
Nov 16, 2020 07:25 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
chuck1177
Jun 7, 2015 10:18 AM
ogre
Jun 7, 2000 08:35 PM
