Winch Question
Old Feb 13, 2012 | 02:54 PM
raceman3's Avatar
Default Winch Question
I have a 2007 Big Bear with a Warn 1500 winch. The winch retracks but does not spool out. From what I've seen this could be the contactor but given they want about $100 for a replacement I'm contemplating just replacing it since the free spool lever is broken off as well. My question is can I install a ProMark winch using the existing mounting plate or do I need a new one?
Old Feb 13, 2012 | 11:27 PM
CraZySteve's Avatar
Most of the Promark, Viper, etc are just old Warn models.. so the chance it will fit are pretty good
Old Feb 14, 2012 | 06:07 AM
raceman3's Avatar
Thanks
Old Feb 14, 2012 | 08:10 PM
beyondupnorth's Avatar
The bolt patterns are likely the same, flip the wires on the winch to see if it runs the other direction, contactors are cheap on ebay, @ $30
Old Feb 16, 2012 | 08:00 AM
raceman3's Avatar
Does it have to be specific for a 1500 or can I use one from a 2000 or 2500
Old Feb 17, 2012 | 04:38 PM
I'd bet they are all the same. If they are different, one for a bigger winch would have a higher amperage rating which would mean it will last your winch longer because it is not being used as hard.
Ken
Old Feb 17, 2012 | 06:11 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
it's most likely the solenoid block- it's common. you can buy a new one on ebay for $20.
SOLENOID RELAY Contractor ATV UTV Truck Winch 12V | eBay
they are all the same. just match up what you have.
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
