Bombadier ds650x Carb
Old Feb 21, 2012 | 04:01 AM
Lesotho's Avatar
Default Bombadier ds650x Carb
HI
I have a bombadier ds650x and recently cleaned the carb but its now leaking at the bottom of the carb non stop how do i fix that, any suggestion?
Old Feb 21, 2012 | 04:08 AM
Welcome to the forum! If you just "cleaned" the carb and didn't replace the needle and seat (needle valve assembly) or checked/adjusted the float level, or the float may be sticking, then these things could be why the carb is overflowing!
There is a CAN-AM section in the forum where you can get further help along with help on any future problems that may come up! OPT
Old Feb 21, 2012 | 04:11 AM
Lesotho's Avatar
Thanks ill have a look at that as i didnt even adjust the float properly, should it be 17mm?
Old Feb 21, 2012 | 04:13 AM
Ask the Can-Am guys about float levels,plenty of people to help you OPT
Old Feb 21, 2012 | 05:58 AM
Oldsman67330's Avatar
There's an O ring around the brass seat that is proned to cracking, they are hard to find online without buying the whole needle and seat for $45, I replaced mine, seems it takes a 2x8mm O ring, but not absolutely certain on the size.
Old Jun 22, 2012 | 02:26 AM
Lesotho's Avatar
HI guys
The fuel now went in my engine is that bad, can i just drain the oil and all will be ok or that can screw my engin up because when i switch it off now there is a nock on the from of the engine dont know if something went wrong there?
Old Jun 22, 2012 | 07:43 AM
Drain the oil now and replace filter!! Gas can thin the oil and cause major damage if it hasn't already done so! OPT
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
