05 Magnum 330 reverse override not working
Old Mar 3, 2012 | 10:33 PM
jcook33440's Avatar
Default 05 Magnum 330 reverse override not working
Any help with this issue?
http://forums.atvconnection.com/pola...num-330-a.html
Old Mar 3, 2012 | 11:59 PM
jcook33440's Avatar
Just pulled the wires from the switch, cleaned then and reinstalled. Still broken. Pulled the speedo off to get to the 6 wire plug but my plug had many more than 6. More like 10 wires. I called it quits... it's 1 am here...
Old Mar 4, 2012 | 09:24 AM
Never had this problem brought into the shop,only had problems with the early models with the over ride module,but yours is built into the speedo. There are some members that have been able to bypass this in the speedo and hopefully they will give you directions. Other than that the speedo would have to be replaced. Plus had the ecm recalls on 05 and 06 models,don't know if this would have any effect on it? OPT
Old Mar 4, 2012 | 09:47 AM
jcook33440's Avatar
I contacted the guy i bought it from (a week ago...) and he said it worked. Maybe a loose wire or something...
Jmuddin284
Jan 19, 2026 07:16 AM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
