01 sportsman 500 indicator lites
Old Mar 11, 2012 | 08:13 PM
SOLOLUCKY's Avatar
Default 01 sportsman 500 indicator lites
the gear selector indicator lites (low, high) , except for reverse, have stopped werking on my quad...anyone else have this situation ?
and how might i get them to start werking again ?
THe quad is fine other than the dash lites...strange...
are they lite bulbs back there ?...
Old Mar 12, 2012 | 07:48 AM
I never had to replace bulbs on this indicator(#4010406),but I have replaced some of the transmission switches. You can pull the pod to check for power with a test light or meter on the indicator panel reverse light wire,if no power then usually the plastic lever could be worn down or cracked on the transmission switch. It's the one towards the rear on on the transmission #3233635. OPT
Old Mar 12, 2012 | 11:08 AM
SOLOLUCKY's Avatar
thanks OPT...you are surely a wealth of knowledge !
Eric
Old Mar 12, 2012 | 01:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
on my 02' there is only reverse and neutral lights and no forward low or high.
Old Mar 12, 2012 | 02:44 PM
SOLOLUCKY's Avatar
HHHMMMM..most interesting..i will hafta investigate under the pod and see what indicators are there then...thanks.
on my '02 330 magnum the low and high did quit werking so i have an angle of attack for that one anyway...cuz i know they werked on that quad....but now not illuminaating
Old Mar 12, 2012 | 03:25 PM
I think Stendori is right,I misread your post! Thought you DIDN'T have a reverse light!! You should only have reverse and neutral that lights up and another space for the hot light,cant remember exactly if any thing else?? Chalk it up to old age or senility I guess,can remember somethings from 20 years ago,but can forget what happened just a couple years back! Guess I'm stuck in the 80's and 90's or just need to check into a memory unit for treatment OPT
Old Mar 12, 2012 | 04:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hell i miss the 80's and 90's and would love to go back.
Jenn1
Sep 8, 2015 09:16 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
Schneider
Jul 24, 2015 05:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
