Turn kill switch on Nuetral Light goes off...
Old Mar 15, 2012 | 07:03 PM
skii0's Avatar
Default Turn kill switch on Nuetral Light goes off...
2005 Raptor 660...the lights will not come on either..battery is charged..any ideas?
Old Mar 15, 2012 | 07:17 PM
Jaster94's Avatar
check your fuse(s).
Old Mar 15, 2012 | 08:03 PM
skii0's Avatar
all good..pulled all the plugs apart and blew em out....
Old Mar 16, 2012 | 04:35 PM
Raptor450's Avatar
The kill switch makes a ground circuit through the handlebars when it's off, so it sounds like you are missing the ground to your lighting circuit, and the ground to the lights is coming through the kill switch when it's off. Without a wiring diagram it's hard to tell what's going on, I think I have a diagram on my other computer I will check when I get to it.
Old Mar 16, 2012 | 06:08 PM
skii0's Avatar
Thanks!...its weird I started it up and ran for a bit then cut it off to add more fuel..then that was it...nothing...
Old Mar 17, 2012 | 04:17 PM
Raptor450's Avatar
OK so I have the diagram in PDF form, I will post it here so we could all look at it but I don't know how so I will need some help doing that.
I was wrong about the kill switch being ground, it is actually positive on the 660. The 24 volts + comes from the key switch wiring on the brown wire and powers up everything, including the neutral light and the headlight switch. The kill switch just sends power to the CDI box, so something could be going on with the CDI box or the plug to it. You could try and unhook the CDI plug and then try your lights and see what happens, it may take a process of elimination like that to figure it out. Otherwise you will need a volt/ohm meter to test the circuits.
Old Mar 20, 2012 | 07:17 PM
skii0's Avatar
ok the lights come on and everything but now when I hit the start button the solenoid just buzzes...charged battery but maybe it doesnt have enough cranking power??
Old Mar 20, 2012 | 07:22 PM
skii0's Avatar
the lights won't come on I mean...the neutral light will stay on when the kill switch is on though..also it takes a while for the nuetral light to come on its very dim then slowly gets brighter..
Old Mar 20, 2012 | 08:34 PM
Raptor450's Avatar
[QUOTE=skii0;3103376]the lights won't come on I mean...the neutral light will stay on when the kill switch is on though..also it takes a while for the nuetral light to come on its very dim then slowly gets brighter..[/QUOTE
Did you do anything as a test to make it change?
Old Mar 20, 2012 | 08:58 PM
skii0's Avatar
blew the rectifier plug out again with air...
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
jrooker6
Jun 17, 2015 12:28 PM
