suspension
Old Mar 17, 2012 | 09:11 PM
irinman2424's Avatar
Default suspension
on my 500 its set from the dealer but when I am trail riding I wish it was a bit softer but when I am hunting or hauling wood and stuff I wish it was a bit stiffer (have one of them racks that fit into the trailer hitch and with a deer on it it sinks and drags the ground) how hard is it to change it? and what way do I need to go with the adjuster for each setting?
Old Mar 17, 2012 | 10:40 PM
user493's Avatar
Moto Psycho
The easiest way I've found is to jack it up take the wheel off so you have room to work and there's less compression of the springs. You should be able to tell which way to turn it and it only has 5 notches. My biggest problem is that the wrench I have now is too big to fit on there. Some guys just use channel-locks but I haven't tried it.
Old Mar 18, 2012 | 05:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
like frank mentioned, jacking it up off the ground takes the weight off and you should buy a spanner wrench to move the adjusting ring on the spring. the higher notches are for the stiffer settings.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
