plastic renew
Old Mar 18, 2001 | 03:40 PM
redrancher350's Avatar
has anyone ever used this on there quad? i heard that it causes the plastic to fade or loose it's color. is this true?
thanks
Old Mar 18, 2001 | 04:16 PM
DIEhardRlDER's Avatar
I bought some and tried it on a little piece. My quad has 13 year old white plastic so it didt help. I actually had to sand a top layer off to get ti to look good. Ur goign to ahve to buy some more sand paper if ur going to do it. It alot of sanding. It sure alot chepaer than new plastic
Old Mar 18, 2001 | 05:07 PM
paulgp602's Avatar
I use tire wet to shine the plastic.It works really good.
Old Mar 18, 2001 | 06:44 PM
TRAIL's Avatar
alot of people on here use mop-n-glo.
i decided to go and buy some today but when i got to the walmart i saw some stuff sitting right next to mop and glo that was a buck cheaper,i compared them and they are almost idenicle,except for the name.Its called "Brite"its in a yellow bottle.It works great!
Old Mar 19, 2001 | 10:10 AM
54warrior's Avatar
I know someone who has used the plastic renew, they spent alot of time on it, and it turned out great. If you have the time to do it, I would use the plastic renew. Just don't spill any gas on it when you get it done, otherwise, it will look like crap.
Old Mar 19, 2001 | 11:36 AM
trapperb1's Avatar
I have used Plastic Renew and it turned out great. I took the time to do it properly and that's the trick to it. You can't be in a hurry. Take each piece and sand them so smooth that you can't feel anything wrong anywhere. If you can feel it, it will show later when you put the finish on. Also, keep it very clean.
I used it on my wife's '93 EX. I took almost 2 weeks to sand, then I put on 9 coats of the finish and steel wooled it after every 3rd coat. Looked great and really increased the resale price.
Old Mar 19, 2001 | 12:13 PM
i only have really bad scuffs, and just a couple scratches. can i get by with just using a couple of coats of the stuff in the bottle, then stell wooling it? but i will sand the scratches no matter what.
Old Mar 19, 2001 | 05:15 PM
RedDog400ex's Avatar
It works good, but if you have deep scratches it dosn't work so good because you'd be sanding for a month, but for the small scratches it works really good.
Old Mar 20, 2001 | 08:46 AM
01450ES4x4's Avatar
What kind and what grit of sandpaper do you use to sand out scratches. Im interested in doin this to my uncles old 4-wheeler. Thanks
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Elkaholic
Sep 6, 2015 02:44 PM
