CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
D4 7.5 amp fuse keeps popping
Old Apr 2, 2012 | 06:21 PM
blowedpony's Avatar
Default D4 7.5 amp fuse keeps popping
Where do I check to fix this issue? The fuel pump cycles but starter won't turn and no lights. When I replaced the fuse, it started and showed a red engine light upon startup and then immediately popped the fuse and the next one I tried. Any help is appreciated. Thanks
Old Mar 11, 2013 | 08:11 AM
UTU's Avatar
UTU
Default Fixed ????
You ever figure this out?
F4 = Speedometer/Speed sensor/tail lamp 7.5 amp
F5 = Fuel pump 7.5 amp
If its the fuel pump fuse thats blowing could be the fuel sock on pump dirty drawing too many amps or fuel filter dirty drawing too many amps or both. Fuel pump itself could be drawing too many amps (going bad). If its the other 7.5 amp fuse blowing could be short in tail lamp/speedometer/speed sensor.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
