Scrambler hub
Old Apr 21, 2012 | 05:21 PM
Tayman1102's Avatar
Default Scrambler hub
my front right wheel will not engage...ever. I was thinking it was the fluid but seeing how it will not engage I don't know. the front left engages and disengages but it is still pulling a tiny bit. Armature plates? Thanks.
Old Apr 21, 2012 | 05:36 PM
Just answered you pm,but try a fluid change first. Plus check that the gray and brown wires are connected under the front panel(plus you can use a volt meter or test light to make sure power is going to the strut(gray wire is hot,all brown wires are ground or just ground to frame). If hub is dry check for oil behind the hub and strut(possible hub and strut seal replacement needed) If you tear into the hubs replace BOTH armature plates as the other side will probably give you trouble later also.Plus check the bearings for any roughness,the hilliard assembly for proper operation of the bearings and cage as you twist the inside. Also make sure the strut coil sleeve is not damaged along with the inner pole of the strut that the coil fits over. Also the inside of the hub where the hilliard rides should be smooth and not pitted. OPT
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
