CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2005 bombardier ds650
Old Apr 23, 2012 | 09:38 PM
crashmaster92's Avatar
Default 2005 bombardier ds650
I was wondering if you have to put oil in the magneto cover? And if so, how much? My four wheeler was smoking ont the vent hose but I didn't know if it just was cause I just put it together. I just don't want to mess anything up.
Old Apr 24, 2012 | 11:49 PM
PapaWheelie's Avatar
Oil only goes in the oil tank below the headlight. About 3.3 quarts. The 650 Rotax is a dry sump system, so the oil pump works to keep most of the oil up in the tank. Some oil vapor out of the crankcase vent is normal, a lot can indicate a problem. You state that you just put it together, but you did not say if you replaced the piston ring. It's possible that if you did replace the ring, that it needs time to seat and seal the cylinder correctly. Someone else can chime in on the ring, since I have not had to do that (yet)
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
