big bear rear axle need help identifying part/bearing
Old May 3, 2012 | 07:01 AM
lugnuttz's Avatar
Default big bear rear axle need help identifying part/bearing
i am trying to fix my atv after sitting for 2 years due to lack of money to get the work done ...
the machine is an 87 yamaha big bear(ymf350fwt) 4x4(full time)..any 87-95 solid rear axle yamaha machine would be the same
my current dilemma is my rear diff is trashed...i bought a set of internal diff bearings but i found out afterward..there is too much damage inside...i need a new rear diff...i located a good used one in a similar machine..same diff same internal gears and parts but different swingarm design
so i will be re using my swingarm however there is a bearing that i need but i can not locate in an oem parts microfiche...
the bearing is located (if you are looking at the back of the machine) on the right side of the diff inside the end of the axle tube\part of the swingarm nearest the brake assembly or right side rear tire ...
for anyone who looks at the microfiche i do not need #12,and 14...those go into the sides of the diff case...here are a few pics of what i need
here are a few pics
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
Peter_
Jul 18, 2015 07:06 AM
Rider252
Jul 6, 2015 03:37 PM
