high comp piston 300ex?
Old Mar 18, 2001 | 11:00 PM
REDTEAM's Avatar
Hey im gonna be getting a High compression piston (wiseco) and i want to know what the highest compresion ratio i can have without running race gas, I have recently put a cam and new rockers in, I am planning on using the stock bore.
Old Mar 19, 2001 | 05:47 AM
alljuice's Avatar
Old Mar 19, 2001 | 10:29 AM
REDTEAM's Avatar
Thanks, anymore suggestions?>
Old Mar 19, 2001 | 01:43 PM
ugly's Avatar
I have some questions.How big of a difference did the pipe and cam make.I am buying the 300ex from ym dad and plan to add these before I go big bore.
Old Mar 19, 2001 | 07:17 PM
REDTEAM's Avatar
Oh i can tell a HUGE difference in top end!! it is FAST!!! just make sure if you get the cam to make SURE you get hardened rockers! thats a MUST!
if you have any other ??? about installing or anything e-mail me
Old Mar 19, 2001 | 07:19 PM
REDTEAM's Avatar
also get a good pipe and a jet kit! that helps ALOT
Old Mar 19, 2001 | 11:25 PM
ugly's Avatar
Thanks for the advice.THe mods I have planned for the motor are.TC suppertrapp shorty pipe,K&n filter,Ported and polished head,bore .040 over,400ex carb,bigger valves,TC cam and valve springs,Hardfaced rockers,Hinson clutch basket,barnett clutch,and an oil cooler.
For the suspension and handling works pro series fronts,works duracross rear,lonestar axle,fastline brake lines,Ac full chassis skid,Ac swingarm skid,Ac pro pegs,6 ply razr's all way around on douglas wheels,and other things.
As you can tell it will be set up for xc and will not get done over night could be a couple of YEARS.First i got to buy it.
Old Mar 20, 2001 | 10:20 AM
REDTEAM's Avatar
thats gonna be a sweet quad!
Old Mar 21, 2001 | 12:02 AM
AdrenalinJunkie's Avatar
I put a 10.5:1 in mine.....i called up TC racing and told him i wanted to keep the stock bore and this is the set-up he told me to use (minus his racing pipe...too expensive and loud!) i really like this set-up....i can keep up with just about anything in the woods.....cr125's included! about the hardened rockers Tom said i wouldnt need them and i havent had a single problem out of it yet.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Steeldon
Sep 9, 2015 09:38 AM
atvcollector
Sep 8, 2015 05:11 PM
