Speedometer Repair?
Old Mar 18, 2001 | 11:26 PM
BigBubbaQuad's Avatar
While riding this weekend, I managed to roll the Xped (slowly) on to its side on an uneven downhill. When it rolled the Spedo pod came to rest on a tree, the black plastic having stopped the bike from sliding and the plastic was pushed in 1/2 an inch or so. With help I pulled the bike back and up and the plastic snapped back to normal, BUT the face plate on the spedo is bent now.
The spedo works fine, it's just that the top edge of the alum.face plate( with the numbers on it) is bent upward at a 80 deg. angle and the back light can be seen glowing. Glass and all else is intact.
The Question: Can the spedo be opened to bend the plate back?
Old Mar 19, 2001 | 12:44 AM
425Xpedition's Avatar
bubba,
I have not figured a way to get the speedo apart. The aluminum ring is what holds the speedo together. If you get the ring off it probaly will not ever go on again. If you figure it out hpw to get it apart let me know. I need to get the water out of mine.
Old Mar 19, 2001 | 01:34 AM
ZoomZoom's Avatar
The plastic casing on mine was destroyed in my last roll-over. My solution: I took a tin can, a dremel tool, clear plastic and made a new case, just can't reset the odometer. But I also found an old Suzuki speedo at a second hand store, and it matches at the cable control and seems to work. Hasn't been installed yet.
Old Mar 19, 2001 | 12:11 PM
MEANGREENMACHINE's Avatar
Be careful when messing with your speedo. The 4wd will not work if the speedo isn't functioning properly. I had to replace mine. It was about 160 bucks for the speedo. So be very careful. If you are worried about breaking it don't mess with it if it still works fine.
salixair
Nov 3, 2015 08:25 AM
firsttimerider
Sep 20, 2015 09:07 PM
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
