ATV Shocks
Old May 24, 2012 | 11:41 PM
GoFastCat 00's Avatar
Question ATV Shocks
Hey.. I was wondering if ATV shocks have to replaced eventually? My Arctic Cat bounces like no other when you push on the rear rack several times. The front suspension works beautifully, but the back is horrid. Is there a way to adjust the suspension?
ATV: 2000 Arctic Cat 500 4x4
Thanks for any tips of information.
Old May 27, 2012 | 09:13 PM
I really need help you guys! Anything would be appreciated.
Old May 28, 2012 | 07:46 AM
benjaminjones's Avatar
Talking
Hi bud,
I sometimes share your frustration as replies often run thin here
Not exactly sure of your shock as fitted there but some can be adjusted & serviced. You'll need to pull it out or consult a service manual for precise info.
Bushings can be siezed up? Both shock and trailing arm units to be checked.
Spring tension / pre-load setting? Is it adjustable?
How's tire pressure, can also affect handling and bob all over the place.
Many forget that front set up can affect rear performance. Had same with my DVX 400 {same as LTZ 400} in that front [PEP & Lone Star] was so soft that rear [stock] felt like a rigid dog. Sorted the rear's rebound and spring adjustment to match my weight.
Good luck!
Old Jun 18, 2012 | 11:38 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
yes, shocks will wear out...and benjamin's got good pointers there
Old Jun 19, 2012 | 09:09 AM
TLC's Avatar
TLC
Turn the pre-load collar to a stiffer setting with a pipe wrench and see if that helps. Should be 5 settings on it,unless its already set to the stiffest setting.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
