check valve
Old May 31, 2012 | 09:05 AM
randy45's Avatar
Default check valve
can anyone tell me what the check valve is for on the carb on a 350L polaris 2x4 and which direction it should point my son took it off
Old May 31, 2012 | 09:52 AM
You can chunk it if you want to! Most of em end up missing anyway over the years from vibration. It's a one way valve supposed to be able to let fuel out and not allow water back up through it. Just have your side vent tubes on the carb routed up under the tank and have the one on the carb bottom long enough to go down past the frame so you can see if the carb ever starts leaking from the overflow. Plus on the old 2 strokes always turn the fuel valve off when not in use to keep gas from filling up the crank case.. OPT
Old Jun 1, 2012 | 07:00 AM
randy45's Avatar
thank you very much this was good info
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Unzzy66
Jul 11, 2015 10:01 PM
Sjrpp
Jul 5, 2015 09:04 PM
