AC 2008 H1 650 Belt Slipping
Old Jun 6, 2012 | 10:11 AM
deezna's Avatar
Default AC 2008 H1 650 Belt Slipping
Hi, i'm wondering about getting a snorkel kit for my wheeler but wondering if those kits will prevent water from getting in the belt housing and causing it to slip? Do i need to do something with that piece in the back end that allows all the air in or is there a separate kit for the belt then the regular snorkel kit? Any help would be great. Thank You
Old Jun 10, 2012 | 02:37 AM
Williebee's Avatar
Default AC 2008 H1 659 Belt Slipping
How Deep is the water you ride in ? The snorkle is located high up under the plastics in the front at the handle bars , i've had my 2006 AC 400 FIS 4x4 in water up to the bottom of my headlights without getting water in the belt housing ; but i wasn't movng fast to keep from splashing the water in the creek i was riding in !
I would check to make sure the belt housing seal isn't leaking if you're not getting in water that deep , plus i would check for water in the belt housing when your belt is slipping by removing the drain plug ; then rev the engine in newtral to dry out your belt and belt housing !
I hope this helps .
williebee.......
Old Jun 12, 2012 | 04:52 PM
deezna's Avatar
Thank you, I ride in water over the belt housing cover but when i get water in it, it gets in their fast. I have taken that drain plug off many times and water shoots out of it for awhile. When i look in the back end of the wheeler there is a big black plastic vent like that curls up and down with a big hole that i think the water is getting in at. I just wonder if a snorkel kit will provide something for that.
Old Jun 12, 2012 | 06:19 PM
ac10's Avatar
Default snorkal
yeh thats the famous AC clutch housing exhaust which has an opening facing back of motor...works like a ram forcing water into clutch housing.you can buy kit or make your own snorkals.They are much better and you should never flood.
Jeff Roper
Feb 1, 2022 11:48 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
rgjackson
Sep 23, 2015 01:53 PM
