84 200s carb!!!
Old Jun 23, 2012 | 10:50 PM
84honda's Avatar
Default 84 200s carb!!!
I have a 84 Honda 200s. When I bought it it ran really rough and would only start by jumping it. So I rebuilt the carb (with no manual on how settings went) I also bought a brand new CDI coil & plug wire, and plug. Now when I try to start it, it floods the carb rite away, I meen I pulled it over twice givin it a little gas twice and when I drained the carb it had ALOT of gas in it, I don't think I put everything (jets) back into the carb rite, can anyone tell me what's wrong or how to fix this? It seems like the gas is getting to the carb but no further so it'll fire. I also have good spark!!!
Old Jun 30, 2012 | 12:50 AM
sinsayers's Avatar
first off you need to download the manual and make sure everything is right, adjust the fuel mixture screw by the manual for a starting point then check your float valve and then maybe look at your timing/valve clearance. If you have spark,fuel and air you should get something out of it.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
RticKwad
Jul 21, 2015 03:00 PM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
