2004.5' Sportman will idle but not run
My sportsman 500 ho will start and re in neutral fine but will cough and sputter when you try to drive it away. I had it in a garage and they figured it was the rev limiter which is built into the ecm control modual. I replaced that and it still won't run.
I had to fix the rewind, starter and the bendix this past spring. Just wondering if it could be the stator, coil or override switch.
My father in-laws quad does this on a regular basis. It will idle and as soon as we hit the gas it dies. this is a easy fix. Just pull the carb off and i bet the needle has came loose and is stuck in the main jet. So i took apart the carb and sure enough the little c clip that holds the needle in place had came loose and the needle just fell into the main jet . all i did was put it back together and pinch the clip with a pair of plyers and it is working great now. hope this helps
