carb adjust 02 scram
Old Aug 15, 2012 | 07:06 AM
6jeff6's Avatar
Default carb adjust 02 scram
Can someone walk me through any adjustment that could help my under load or slow going gumming up that I get?
02 scram 400 starts and runs outstanding. Less the 7-8 months off being completely rebuilt(crank seals and all).
Now my issue is under load which is in 4wd in mudhole and you don't slam it full throttle, pulling something and staying half or less Throttle or even someone on the back and you go slow.
What happens is she smokes and sputtered. If you hammer it or sometimes just get on it a little harder she cleans out and is fine. I really need to fix this as this was a huge issue before I rebuilt it when plowing as a person only need half or less..
It either has a 260 or 280 jet I can't remember which but can easily pull Carb if you want. It also has the reeds that are more open(no plastic in the way) and aftermarket pipe with open muffler . Also just put kit in drive clutch and new belt. She's a wheelie machine if you get traction....
Old Aug 15, 2012 | 07:34 PM
You might have it jetted too rich with a 260 or 280 main jet(240 stock)even if you do have an aftermarket pipe,plus either Boysen or V-Force reeds,etc. They can dump in a lot of fuel into the engine quickly and the engine may not be able to take it at lower rpms or under a load. You can drop the carb slide needle a couple positions first to see if leaning it out on the bottom and mid range helps. Sometimes people over compensate on main jets.If this doesn't help then start with a 245 or 250 main jet and go from there. Remember to do a spark plug check between jet changes to make sure it's not too lean. OPT
Old Aug 15, 2012 | 09:13 PM
6jeff6's Avatar
Thank you I will try the slide.
I also run a br6es plug if that makes a difference.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
