2003 500HO waterpump does not turn
Old Aug 28, 2012 | 05:06 PM
hustler2's Avatar
Default 2003 500HO waterpump does not turn
Was overheating and took waterpump apart and it does not turn when cranking engine.Any ideas? Thanks
Old Aug 28, 2012 | 05:47 PM
Welcome! If you're talking about the impeller not turning its possible the impeller nut has backed off and not spinning on the shaft.Plus running hot or trapped air can damage impellers from cavitation and distort and melt impellers if the condition goes on long enough.. If it's the shaft itself not turning then there's some internal problems that have happened. OPT
Old Aug 28, 2012 | 06:27 PM
hustler2's Avatar
Default 2003 500Ho water pump not turning
The shaft is not turning ,thought somebody might have seen this? Will be taking apart this weekend and will let you know ,thanks
Old Aug 28, 2012 | 07:08 PM
If the shaft isn't turning it's probably either snapped the locating pin on the oil pump drive gear(would have to break the retaining bolt also?) or the shaft itself may have fractured? Look here under "oil pump" under your model. Browse I've had a crank gear spin that drives the oil pump gear but not the oil pump gear or shaft itself,but anythings possible. OPT
Old Sep 2, 2012 | 07:22 PM
hustler2's Avatar
found spun gear that drives oil pump on the counter balance shaft> Does it pay to look for a used shaft? Thanks
Old Sep 2, 2012 | 08:15 PM
Order a new shaft,I would trust a used one. OPT
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
95wolv
Jul 17, 2015 08:13 PM
