Gas gauge not working properly
Old Sep 3, 2012 | 12:04 AM
Norternguy's Avatar
Default Gas gauge not working properly
I am having issues with my gas gauge.It reads full all the time.
It would be nice if it was but its getting to be a pain in the back side.
How do these gauges work?
Is it another sensor issue. I do not yet have a manual for it.
Hoping someone can point me in the right direction.
Thanks
Old Sep 3, 2012 | 07:08 AM
If you have carb model you have a float level system similar to what's in a regular toilet float arm and float.Quite possible the float arm probably needs to be bent a little to keep the float from touching the tank causing it to stick which could show incorrect fuel level.Just pull it carefully out of the tank ,move the arm up and down slowly to make sure the display changes and bend the end just a tad and see if it helps.. If you have an efi system the float is built internally with the fuel pump,pressure regulator,etc.They can stick also,but move straight up and down on the column. OPT
Old Sep 3, 2012 | 12:41 PM
Norternguy's Avatar
Sorry about that,its an 06 700efi sportsman.
Thanks, I will see what I can do with it.
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
