07 Sportsman 800 efi Code 51 & 52
Old Sep 10, 2012 | 11:01 AM
HaydenS's Avatar
Default 07 Sportsman 800 efi Code 51 & 52
I know what the codes are but what would cause both injectors to stop working? I parked it in the garage the other night and the next morning went to load it on the trailer to take it out scouting for Deer season and all it did was roll over. I'll check the fuel pressure tonight but is there anything else to look for. Another thing. What do the 4 fuses protect? I can not find any labels or anything in my book. 5amp? 15amp? 1st 20amp? 2nd 20amp? Thanks
Old Sep 10, 2012 | 12:26 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
bad / lose connector, blown fuses, bad ecm, no fuel getting to the injectors....
so- what do the codes mean?
Old Sep 10, 2012 | 01:52 PM
HaydenS's Avatar
Code 52 injector 2 : open load
short circuit to ground
short circuit to battery
code 51 injector 1 : open load
Old Sep 10, 2012 | 03:38 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
pull out the efi fuse and check for continuity-
follow eack injector lead back and inspect the connections- unplug and replug the connectors. Look for other lose wires- or wire insulator that might be pinched or rubbing off exposing the copper. Make sure battery connections are tight.
Old Sep 10, 2012 | 04:05 PM
HaydenS's Avatar
I don't know which one the efi fuse is. its not in the book. That was 1 of my questions
Old Sep 10, 2012 | 04:08 PM
HaydenS's Avatar
I just noticed that I have 2 wires that I can use for my winch that I didn't use.
Old Sep 10, 2012 | 04:09 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I dunno- all the fuses on my can-am are labeled....
Old Sep 10, 2012 | 04:47 PM
15 amp fuse is the efi power,5 amp the speedo,20 amp for the chassis,and 20 amp for accessory power. Codes don't always point to the exact cause. Check the fuses along with underneath the fuse block itself for any wires that may have grounded to the frame or loose from the fuse block. OPT
Old Sep 10, 2012 | 05:35 PM
HaydenS's Avatar
Thanks OPT. Do any of you know how to check those relays with a multimeter?
Old Sep 10, 2012 | 05:48 PM
The two four pin relays control the fan and fuel pump/injectors and get power from the ecu.. Just swap relays as they are both the same. If no difference you can rule out the relay as the problem. OPT
