Bayou Splines...
Old Mar 21, 2001 | 04:14 PM
Bayou3004x4's Avatar
Hey there guys.... i have a big problem i have the money to get a dirty howies locker, but i have been told not to get one cause i will strip my front splines, because they are shallow??? is this possible to strip solid metal like that??? HELP! all insight welcome -Thanks
Old Mar 21, 2001 | 06:04 PM
ThEbEaST's Avatar
I have stripped the rear hub splines before I dont know if it is the same for the front. The threads for the nut were messed up. The nut wouldn't stay tight and the splines in the hub stripped. The dealer said Kawi makes the hub splines out of softer material than the axle splines because a hub it cheaper than an axle is.
Old Mar 21, 2001 | 06:27 PM
so i should be safe?
Old Mar 22, 2001 | 03:20 AM
Tree Farmer's Avatar
A locker will stress the driveline more than a differential. Larger, more aggressive tires than stock stress the driveline, too. Lots depends upon the roughness of the service you put your quad through.
Stripping splines on a driveshaft/universal joint is a pretty severe and drastic happening; I doubt a locker would be a significant contributing factor. Consider: What if, both front tires, pointed straight, have equal traction (with a differential)? How could a locker stress the driveline further?
The additional stress contributed by a locker would occur mostly on turns, under power; the CV joints are probably at greater risk than the hub splines. Keep this fact in mind; and, if you decide you need a locker, I'd recommend you go for it.
Tree Farmer
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
