HELP! My 250EX Throttle is suck closed
Old Oct 9, 2012 | 10:01 PM
kathykirk99@yahoo.com's Avatar
Default HELP! My 250EX Throttle is suck closed
Hi! I need some help.
My 2001 Honda 250 EX quad throttle is stuck and won't move. Any one out there know how to fix? Can I open the little box on top of the throttle (3 screws) and do something in there? Or does the entire unit need to be replaced?
THANK YOU FOR ANY HELP YOU CAN SEND MY WAY!!
A fellow quad rider,
~Kathy
Old Oct 10, 2012 | 07:12 AM
budedm's Avatar
yes, you can open the box, and in fact you SHOULD open it. The problem could be in there and a simple fix. Or it could be a frozen cable, in whiich case you need a new one (I have tried many, many times to repair frozen cables and wasted my time in every case). The problem could also be in the carb. Let's hope not.
Old Oct 11, 2012 | 06:39 AM
Jaster94's Avatar
i concur, sounds like a frozen cable. probably dirt/grit all in it. a replacement cable should do it. you'll be able to tell how it comes apart and just as easy putting the new one back on.
budedm, is there a way to inject graphite into these newer style cables to help out? i've been trying to figure out a way without puncturing the jacket/sleeve. i just about decided to give up unless i put the graphite in a bowl and try to submerge the ends in it and work the cable back and forth. what do you think?
Old Oct 11, 2012 | 06:45 AM
budedm's Avatar
Get one of these
12-7058 - Cable Lubrication Tool
Ronk407NY
Feb 13, 2016 11:05 AM
Bratman2
Jul 23, 2015 12:36 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
cSchwartz
Jul 9, 2015 02:40 PM
