ES Shift Problem
Old Oct 10, 2012 | 02:59 PM
sbgolfing's Avatar
Default ES Shift Problem
I have a 2004 Honda 250 ES that had set up for 2 or 3 years before I had purchased it. I have had the carb cleaned. It runs and shifts fine but will occassionally throw a flashing light in 1st gear (it flashes 10X) no matter which gear you are running in. It will continue to run in the gear that you are in. I can turn the key off and back on it will shift down to nuetral. Sometimes you may have to rock it to get it back to nuetral. Then you can start it up like nothing is wrong. Could it be an angle sensor or something else?
Old Oct 10, 2012 | 07:54 PM
savage5480's Avatar
A guy i know his does the same in 1st and 3rd gear(s)
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
