250r oil
Old Mar 21, 2001 | 08:11 PM
250R86's Avatar
hey i have a 1987 trx 250r w/ fmf pipe, fatboy silencer, ported, shaved head, bored .60 over...what oil would u recomend running and at what ratio? and also should i be running race gas???
Old Mar 21, 2001 | 11:08 PM
Z71's Avatar
Z71
I have a 86 250-r with fmf phatty, fmf silencer mild port, rad valve.I run Honda HP2 racing oil at 32:1 ratio with premium gas. Comp. is at 140 psi cold.If your comp. is 160 or higher you may want to run a higher octane fuel.Keep a close eye on jetting , ride on..... ride red.....
Old Mar 22, 2001 | 11:43 AM
trapperb1's Avatar
I have an 86 and 87, both FMF pipes, K&N, CR head gaskets, Boyesen reeds, stock carbs rejetted, etc.
I run 92 octane pump gas with Golden Spectro. I mix at 40:1 for sand, 50:1 for dirt. Mixes easily and stays mixed. Never had a problem because of it. Just run the 92 octane, you should be fine.
Old Mar 25, 2001 | 01:07 PM
Boogie's Avatar
I have a 88 250R with the old style FMF gold series pipe and silencer,a rad valve,a shaved head,40 over,and a mild port job.I run HP2 at 32;1 with 93 octane pump gas and I have no problems. 88 250R ,00 400EX
Old Mar 26, 2001 | 08:46 AM
250R86's Avatar
my 250r just blew up running Cam2 and H1r at 32:1..do u think i is from that mixture or u think it is jetted wrong?
Old Mar 26, 2001 | 10:07 AM
trapperb1's Avatar
What do you mean by it "blew up?" Have you pulled it apart and seen the damage?
I've melted pistons and lost all compression from too lean jetting and fuel/oil mix.
I've siezed motors from air leaks and had to replace everything.
So, tell what happened and people can give you more answers.
Old Mar 26, 2001 | 11:45 AM
250R86's Avatar
yeh i took apart my motor...the piston was semi-seized from the metal shavings from the hole in the piston but i cleared that out, everything else seemed to be fine. do u think this is from the wrong jettin or wrong mixture? everyone is tellin me 32:1 should be fine. i have a 169 main jet and i dont know about the pilot jet. also if there is anything else that could have caused the top end to go
Old Mar 26, 2001 | 02:00 PM
trapperb1's Avatar
From the hole in the top of the piston you were running too lean.
Take off your left side cover and see if there is any oil at all in there. If there is, you have a leak in the crank seal and this will cause you to suck air into the crankcase and "lean out" your mix and smoke your motor. According to my local Honda dealer, you should replace this seal every time you do a top-end. Lots of people don't pay any attention to it and continue to have the same problems of piston melt down, etc.
Also, you could have a air leak around the base gasket of the cylinder. This will cause the same problem.
If you pull the jug off and take out the piston, give your rod/crank a check, make sure not worn out. I didn't do this and seized one that way also (I think I've made most of the mistakes at least once already).
I don't know if you're running a stock carb or not, but, if stock, jet sizes are .160, .162, .165, .168, .170.
No, a mix at 32:1 is not a lean mix by any means. It's fatter than what I run, but I use a different oil. Your "mix" didn't cause the melt down.
Old Mar 26, 2001 | 03:18 PM
250R86's Avatar
im sory it was a 168,anyway thanks for ur help...is that crank seal hard to replace???
Old Mar 27, 2001 | 11:57 AM
trapperb1's Avatar
No it isn't and it's only about $15 for the seal at Honda. No special tools required. Check your Clymers manual. It'll tell you how to do it.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
