Tire???? on an 08 sportsman 800
Old Oct 16, 2012 | 10:25 PM
badazzpred's Avatar
Default Tire???? on an 08 sportsman 800
Does anyone know if there would be any clearance issues to the tie rods and or the struts if I were to run a 26/9/12 front tire verses my stock 26/8/12 tire?
Thanx
Old Oct 17, 2012 | 05:52 PM
badazzpred's Avatar
No One???
Old Oct 17, 2012 | 06:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think 9" is what i ran and don't remember and issues w/ rubbing. 10" will rub for sure. but i also had aftermarket rims now that i think of it.
Old Oct 17, 2012 | 07:19 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
No rubbing depending on the tires tread. I recently put the maxxis zillas (9" wide fronts)on my 07 and the clearance is extremely tight. (1/8" tight!) I added washers to the backside of my wheels to get 1/4". Any aggressive tire with treads that wrap around the sides will be close but will fit.
Old Oct 18, 2012 | 12:11 PM
1eep's Avatar
i was running 27x9x14 on the front with no issues.
Old Oct 18, 2012 | 05:53 PM
bobx2's Avatar
There is a very good chance they will rub the tie rod ends if you are running OEM wheels.
Old Oct 18, 2012 | 06:44 PM
badazzpred's Avatar
Well I decided to go with a set of STI HD1's with a 4/3 offset 12"x7" and a set of STI Black Diamonds XTR's 26/9/12 fronts and 26/11/12 rears should be the ticket.
Thanx for all your help
Old Oct 19, 2012 | 02:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a buddy at work has those tires and loves them. good luck.
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
