Tie rod lengths??!!
Old Oct 22, 2012 | 10:10 PM
PRNDL's Avatar
Default Tie rod lengths??!!
Ok, I purchased an old 1995 Polaris 250 Trail Boss. It was in bad shape. I rebuilt the engine and everything else. It runs great and so on. Here is my issue, my handle bars and right wheel point perfectly strait. The left wheel points Way to the left. The left tie rod is adjust to the maximum setting, so i can turn it back in. I have a funny feeling that the left tie rod is too long. Are the left and right tie rode different lengths? Maybe the last owner put a longer right tie rod on the right side. What do you guts think? Any experiences?
Old Oct 23, 2012 | 08:40 AM
Tie rods are the same length unless previous owner swapped one from a different machine.You can loosen the tie rod lock nuts and and the rod has a 3/8" flat spot to adjust with a wrench. OPT
Old Oct 23, 2012 | 09:54 AM
PRNDL's Avatar
Do you know how long they are soposed to be. They measure a foot long each. This includes the threaded areas
Old Oct 23, 2012 | 12:08 PM
No,don't know the actual length,never put a tape measure to em,BUT sounds about right. Different models do have different lengths and diameter shafts.Look here under your model and will show the shaft # itself along with the tie rod ends that's supposed to be on your 95 Trail Boss. Browse OPT
Old Oct 28, 2012 | 09:31 AM
papathud's Avatar
my experience and im on my first polaris,but i purchashed after market new tie rod ends on ebay and ended up with too much length to adjust mine in to where they werent toed inward.i actually cut some lenght and rethreaded my tie rods only took bout a half inch on each to get me straight again
Old Oct 28, 2012 | 11:23 AM
PRNDL's Avatar
You are the man. Thats just what I neede to hear. I thought i was going out of my mind. Thank you. What did you use to cut them without damaging the threads?
Old Oct 28, 2012 | 02:47 PM
papathud's Avatar
Default tie rods
i used a thin cuttin wheel on a 4 inch grinder then chased the remaining threads pretty sure if my memory serves me that its a standard fine thread thats found in a basic tap and die set. i pondered it long and well lol befor i decided to do it , but it turned out fine ,problem solved. i took off bout three eights to a half inch on each rod ended up with plenty of adjustment
Bratman2
Aug 6, 2022 01:42 AM
MikeyBoyesq
Nov 27, 2020 02:44 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
