1990 trail boss i need help with a repair question (first post)
Old Nov 5, 2012 | 04:49 PM
yc456's Avatar
Default 1990 trail boss i need help with a repair question (first post)
I have a 1990 trail boss 250 and this is my first post by the way I cam here for yelp it has a gas leak and I have found that it is leaking out of the fuel shut off valve on the bottom of the gas tank and it I went to all of the auto part stores and they don't have them and I've talked to Polaris and different shops and they all have told me that Polaris no longer makes nor sells that part and I can't find it on eBay and I can't tun it because gas plus hot motor can't end well also another problem that it has is that it has a brand new battery atleast that's what who I bought it from said however I have to jump it everytime that I wanted to ride and then I rode it for an hour and a half attempting to charge the battery but it still won't start and then one last thing shouldn'tthese have a pull start back up because I can't find it for the life of ne
Old Nov 5, 2012 | 06:49 PM
94harley's Avatar
Polaris Fuel Strainer Assembly Trailblazer Big Boss Trail Boss 1992 7051002 | eBay
ebay listing 200827916946
Old Nov 5, 2012 | 06:51 PM
Welcome! #7051006 fuel valve off a 1994 Trail Blazer will fit your 90 model and is $23 at Cycle Parts Warehouse.Still shows to be available. The older a machine gets the harder parts are to find.Use a volt meter and check charging at the battery while running,should be between 13.5 -14.5 volts. If just shows battery voltage then a burnt out regulator rectifier is the most common cause. You can find them for your model here. Polaris ATV Rectifier Regulator
Recoil starter is on the right side of the engine. Probably rope missing from internal damage. Look here on you model under "recoil" and you can find what all parts are involved. Browse
OPT
toonces
Oct 16, 2019 12:11 PM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
