Polaris 200 Phoenix
Old Nov 19, 2012 | 06:47 PM
Blown284's Avatar
Thumbs up Polaris 200 Phoenix
HI everyone! I recently had to clean out the carb on my '05 Polaris Phoenix because it wasn't running right. I had to clean the carb on my other quad (KFX 700) so I'm fairly experienced.
After cleaning the carb I made sure to clean out the jets really well and put everything back together. Bike will now only run with full choke and I have no idea why I didn't mess with the air/fuel or idle screws.
Also, is there a secret to adjusting the throttle cable? The throttle cable on the handle bar side is really loose. Any tips would be greatly appreciated. I'm ready to light this little bike on fire LOL.
Thanks!
Old Nov 19, 2012 | 07:03 PM
Throttle cable has an adjuster under a rubber sleeve to adjust slack. If it only runs good with the choke on then either you may have a fuel supply problem(remove the fuel line and check fuel flow) or may have some trash that may have gotten into the needle seat area slowing fuel flow or jets may be partially stopped up. Ethanol can eat up the insides of fuel lines also depositing little black specs into the carb stopping things up. OPT
Old Nov 19, 2012 | 07:13 PM
Blown284's Avatar
Understood on the fuel lines. I had the same issue with my boat and had to replace all the fuel lines, add a water/fuel separator and also install new low pressure fuel pumps. Fun fun.
I thought maybe I didn't hook up the carb right but it was super easy just had to play around with that needle that screws down on the top ---- horrible design. LOL. I suspect that's the first place to adjust vs. on the handle bars (throttle adjustment) there, right?
BTW, thanks for the help!
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
